I see they have a Bully that fit's the Furds... I didn't even realize they wheren't in joysey...
the biggest issue is not having components in your hands to see/operate and if they would/could work together..... the trick is to be able to marry up a door like that, to a nice short straight dizzle fill like the one I posted...
and even if I get and shorten/mod a fuel fill from say a f-250, excursion, etc, the plastic fuel neck mount behind the door will be at some stooopid angle that makes the whole setup unusable...
I'd need to figure out a way to mount the neck I linked behind the door... now if I TIG'd alum, I could easily weld some alum plate as a recessed cylinder kinda mount behind the door for the fuel neck to mount to... but alas i'm an alum idjit...
I'm sure I'll figure something out by tank time in july... I may just order a door, that neck, than figure out how to make it all work.. maybe I can have my tank guy weld something up when he does the doghouse... I'd really like to run a door of some sort, but if pushed, I could just mount that neck to the surface and have an exposed cap...
on an actual rig update.... got all the fockup
cut out and ground down yesterday... cut, fitted and tacked the 4 new tubes in for the coffin wall behind the tank.... and cut and fit those 3 new alum walls for it... no pics, as it's mid process nothingness at this point..
next weekend I'll do the panel mounts for the 3 walls.. and work on getting the floor in... I'm hopeful with a good sat/sun I can actually be done with the coffin...
than I only have the tubegate panels and 4 bent corner pieces left...
