wow great work, and very handsome pup!
That k5 in there is looking quite neglected...![]()
BOO!
We need a dislike button for that!
but I have to stay on this track for now, for once... can't spare labor/cash to do anything to that.. heck, I'm pilfering from it....
Looking good as always, cool to see this idea coming together.here's how the switches are working out....
ss black acorns out front....
to ss countersunks....
Check this out:
https://www.browntool.com/Listview/tabid/344/CategoryID/62/Level/a/ProductID/223/Default.aspx
You can adjust it to control the depth of your coutner-bore. you can adjust it on the first one gradually going deeper until you get just what you want and then lock it down and have a repeatable result every time. Works in a press or hand drill. Old aircraft guy recommended it to me when I was doing a side project at work and wanted to do a bunch of countersunk rivets.
That's the great thing about that tool is you can just lay into it until it hits then move to the next one, Don't hardly need to think about it once you get it setup.It also makes it so you almost don't need to think about being square, you just bear down until it is all the way down flush.neat, never saw that before, thanks.... i see march's birfday present now..
yeah, got a bit deep on that one... usually i'm pretty careful, i've done hundreds on this rig... but when i get in a bit of a rush...![]()
i do have some leeway there.. those are actually "undercut" heads... a "standard" head will bring that back out and work fine on the 1/4" too..
holddowns are basically done.... getting ready to burn in the walls after i make the small front spacer........ than i'll drill the bar stud holes...
holding off on the carrier/UHMV mounting holes till tomorrow.. i have a new tap coming in I wanna try...
That’s all turning out super nice! I can see all that planing and time paying of with the coolest battery tray ever.![]()
I’ve been reading this page so often all the targeted ads I’m getting are for wire harness building courses! Looking great!
