Stomis
Professional Amateur
Well the truck just earned a name. Spit the pump seal out of the transmission pulling into the trans shop to help my buddy work on his mustang. Gentlemen and gentlemen I give you, Snail Trail
Hey your honest and human! We all make mistakes.....
Running 4l60E?
I ask cause I do have a new never ran Yank stall sitting in my garage for a 4l60E/LS combo.
Truck is looking good, looks like its ready! You ever make it to the dragstrip? Season is pretty much over now it seams.
Did you try the Tbrake without the 2step to see what it stalled at?
Congrats on your own shop, hope you like it and it works for you.
You can have the Holley ECU turn on the 2nd fuel pump.
Sounds like you learned a lot with the auto install. Could of been worse, I know someone who just ran manuals and the first auto they installed they tried to bolt the trans up with the converter already bolted to the flexplate like a clutch.![]()
https://www.holley.com/products/exh...ust_manifolds/exhaust_manifolds/parts/8510HKR
It’s too bad your sbc this makes the turbo thing easy and pretty cheap still. At $449... almost a waste of time to fab your own stuff, I don’t know of a quality manifold for that price on a small block..
After all the time you spent cutting weight I would be shocked if you bolted iron manifolds up. I've never seen one that performs as well as a header and even though its a turbo manifold and would still make power, I hate the way all the primaries enter at different points before its large enough, restrictive. Those look like they are for lower power stock engine turbo setups.
Is this going to be drag truck only? You adding another radiator to keep the water cool or just planning on adding ice at the track? Unless its drag truck only I'd do air to air for the simplicity, easier use, and weight savings vs air to water to air. My brother put on air to water because he got it used and it works, but its a PITA to need ice every single pass. He plans to take it off for air to air since its a street truck.
The truck is looking really good, nice work, I want to see some timeslips!
And I agree with others, fiberglass work makes me itch just looking at it.
Sounds like you got the bug without even taking it to the track yet...![]()
Meth/water works good as long as you don’t sit idling for an hour before the run.. me thinks carrying a bottle of c02 to blow cold air on the intake between runs will be fine. Also running the air to water cooler with an electric pump and large reservoir somewhere I’d think it would be fine as long as you don’t hot lap it.
Whats the specs on the s475? Hopefully soon I can start ordering turbo stuff for my s10 build, been looking at the billet vsracing 80mm 83x75.
