Gotcha, I don't understand it to well either. Plan on talking to someone that knows what they're doing before I just start ordering stuff. Any reason for not building a log manifold like kbracing?
Very true, I can see giving up alittle spool time with a log manifold. Being able to mount the turbo is the biggest draw for a log manifold for me, well that and packaging in a small space. Lots of people still make big power with log manifolds and flipped oem manifolds.
You weren't joking, turbo headers on already! saweet!
I'm glad you went with the tubes instead of the cast. I know you can make a lot of power on cast manifolds with turbos, but I can't do anything but wonder how much faster the same setup would be with the proper tubes. Plus you don't want to be one of those guys that makes a lot of power along with a lot of heat since it has 3x more exhaust backpressure than intake boost.
Did you consider merging the two banks earlier?
Is there a reason you need to make the bends going into the turbo flange so sharp? Its almost a sharp corner on the ID. J-bends aren't that expensive and a lot less time consuming than all those pie cuts, and the turn wouldn't be so sharp, more smooth and flowing.
