B
Bent77
Guest
NoSo going back on the Snipe hunt?
If it gets injection it will be MPFI
MPFI FTW!Oh side note
Sold the sniper
Only concern with the Q is off-road. Some of those angles are an issue. And theres those two 11000’+ mountain passes to drive over.Be stubborn and keep it old school, sounds like a exspenive experiment.
I like to have one old guy around to tell us how to tune a quad. No joke Eh!
Never had a problem with my Q off road at the angles. The lack of the automated adjustment for altitude sucked though. I always bumped the timing at altitude and kicked up the idle speed to compensate at low speeds.Only concern with the Q is off-road. Some of those angles are an issue. And theres those two 11000’+ mountain passes to drive over.
Otherwise the Q has always served me well
Did you sell the sniper?So kinda in limbo
When I switched to the Sniper, it said i was making 12” vac not 17” I initially had with the carb. Presumed it had to do with the throttle body
Went back to the carb, 12”. Pulled the intake and resealed. 14”
YesDid you sell the sniper?
Long and short yeah. I have my suspicions.So once upon a time with this engine and the carb initially it had 17" vacuum but then lost it at some point when swapped to efi but you don't know when exactly or what you did to get the vacuum loss? Hmm
Did you check timing chain?Long and short yeah. I have my suspicions.
Did check a couple cylinders for pressure just for shiggles. 150 psi
No but everything on this was fresh new. I can degree it if need beDid you check timing chain?
Timing affects max vacuum
Checked a couple cylinders or all 8....Long and short yeah. I have my suspicions.
Just a couple. Have to pull the headers to check all 8Checked a couple cylinders or all 8....![]()
and edelbrock pro-flo 4A big block will fix that.
1406 time![]()
