Don't suck up to him, he's finally compliant!Campy...I have my bad days too. I easily had a pretty bad 6 months, maybe more. If I was rough on you along the way, please accept my apologies.
Only trying to keep the Tcase forward of the break over point.Skip the ten spline SM465. Too short. Why give yourself that head ache unnecessarily? You have a long box!
Martin
I thought the FiTech used stock mechanical pump to draw fuel into the reservoir, then it bumped it up to proper pressure. Thought that was the big draw of it all.
Isn't a two tank system like that going to generate/invite more problems like fuel heating or vapor lock?That's an option. Most run a high pressure pump and return like you would on a LS or most other aftermarket EFI systems, the fitech has a built in regulator.
I think it's well worth it though. Especially for the kind of stuff we do. If you ran a sump in the tank with the fitech fuel command center that would be sweeeeeeeet.the fitech does have a reservoir setup but it cost more money.
Going to throw this back out there, i want you FITech guys to answer this...
One gallon tank with a electric pump in it. Doesn't recirc to the main tank. How could this not heat the fuel, especially at low consumption, such as crawling?
Weighing the choice between stock TBI and a FiTech type setup. On the negative side for the FiTech is needing a high pressure fuel supply system. Basically the same as if I was doing the Vortec/LS type swap. Debating the +/- of setting up the tanks like you and @Kay86K5.
40 gallon burb tank for the win
