I thought this was an offroad truck, I didn't know it was on Bitchin' rides and needed a tiny tool to measure all the gaps. :coolblue:
Yes and no. Obviously whatever was causing that before is worse now. Need a rear cover, probably both shift forks, maybe some hard parts in between like the front gear set. Going to replace the front driveshaft also
What’s up with the front shaft?
my cases are coming out soon for a rebuild too.
The splines were sticking before Moab. I pulled it apart and hand filed all the splines so it would slip. But it was built wrong from the word go and it has enough play to be a concern
Made it home, but barely. ATF is pouring out of the t case. Looks like the rear of the front output is trying to exit the case
I was wondering how it was going to behave on the way home. Glad you made it.
My bumper is an easy fix compared to yanking that 205 out again.
It popped out of gear several times. Made lots of racket
When I blew the 2nd gear out it Moab, it also drove the front output back hard enough to push the bearing cap out. When I pulled it out to check the leak on the rear output, I didn’t see anything funky
Maybe a good opportunity for a front 32 spline upgrade?
