if you angle the shocks inward a bit so that they don't go through the wheel wells so that the holes in the floor are relatively small and manageable, you could run some shifter boots around them.
Not when you run 2.5 in coil overs and 3 in triple by-pass shocks on each corner and keep it a 4 seater.
Did you use some sort of rubber or neoprene to seal off the shock bodies at the sheetmetal so they can still move a little?
Welcome to the high speed and smooth ride side of CK5.
Cant wait till mine can ride even half as good as yours looks to ride.Wow. I had to reread the thread because it has been so long.
