B
Bent77
Guest
Oh?I also think I found my issue from before...
No one better tell my wife that I spent 1200 times what the cost of the problem was...
FiTech says I can use any of the three feed ports...
Return port is always the return port, but the instructions say pick the feed that works best for you...
So...
**** yes!Finally making some headway...
Worked 37 hrs from Thursday morning through 10:45 this morning.... so not much happened on the the truck until today.
Also looking for SRW hubs...
If you wanna keep those hubs on I have 24 bolt Humvee beadlocks that you can have for free. Just need some 16.5" tars.**** yes!
You can.I thought you could machine those down?
How much of the 14bFF will be left? I'm doing some looking and it might fit better for my 66 C20.Plan is to find/modify hubs on the 60, then gut the 14 for parts.
My current 14 already has shock mounts modified, and the new 14 is a cab and chassis model anyway
Oh great, now you just drove the price up!First off, nice work on the Fitech.
Second, save that 14bff. Jeep guys love to run those c&c 14bolts. They literally bold up under a factory set up TJ/XJ and keep the same track width.
Probably really low, like $50 I'm thinking.Let me put it this way. I have the same axle. I was told by some jeep guys that they like to use them. Not sure what the market is, as I never had anyone bite on it.
