Wow, your wife did all the work
Looks good, are you gonna paint it grey ?
Yeaaaah were gonna need more pictures of that.
Isn't it kind of top heavy with that giant service box?
Not as much as you would think. Its all alum and empty it only weighs about 200lbs more then the steel bed. You do certainly know it's back there but the biggest draw back is visibility. I need bigger mirrors....
Martin
I'm I see this wrong? Or does it look like on the pass side spring perch, where your top plate is, the spring pack might not thick enough. Look like your plate is tilted and not engaging completely on the spring. This happened to me and had to make a spacer to take up the room until I got new springs. In this picture you can see my spring pack was not thick enough.
Long time, no update.... Been busy but I do have some updates.
Had to do some of the small maintenance stuff like changing radiator, heater core and thermostat. Then I decided I was going to try to install these!!!
Michelin XZL 335/80R20
I was able to get a good deal on some ProComp wheels that i felt actually looked decent. I had a hard time finding any 20" wheel that I liked.... Took them all down to my brothers work (Firestone Service Center) and got them mounted. I added 12oz of airsoft bb's to help balance them and this is what they look like next to my 37" MTR's with my helpers.
Swapped to some 56" Chevy leaf springs (running 7 leafs) and built a 1" zero rate to move the axle some, the axle is now 1.25" forward of stock and I have about 5" of front lift. Did a little trimming to the fenders and wheel wells and it looks like the rubbing will be minimal.
Photobucked ruined yet another good thread.. Just found this. Looked interesting.
Thanks for starting to add the photos back to the thread! Did you dill the holes for the tensioner on the alternator bracket? Would like to see that if you could. Also, what is the part number for your AC delete pully? I've been looking for one. Thanks!
@ryoken better keep an eye on this one.
thanks....
i'll go read this....
