What end did you use for the end of that - the 'nut' you swaged on there? And you used the bolt cutter looking swager tool they have? I'm just getting to that point in my build now.
I used the end that came with the kit, pictured here:What end did you use for the end of that - the 'nut' you swaged on there? And you used the bolt cutter looking swager tool they have? I'm just getting to that point in my build now.
but I was able to find a suitable replacement from CAL ranch.
Evidently hose clamps (at least without a bump flair) are not strong enough to hold when going 80mph towing a small trailer.
Yeah, transmission, not power steering, but really that would mean even less pressure. The guys at the hose making place said that it shouldn't build more than about 100 psi and that hose clamps are rated to 150, but that is assuming there is a bubble flare for the hose clamp to seat against which there wasn't. I'm not sure how they know how much line pressure a 4l60e produces, but from my reading online that seems right. The compression fittings are probably overkill but it wasn't expensive for a little peace of mind.There shouldn't be much pressure in the cooler lines since they are supposed to be on the return side of the pump. But I had similar issues on the fill hose from the reservoir. It seems to work better with thicker wall hose.
Edit, just saw this was for a trans and not power steering. Never mind!
Gotta admit, that was kinda fun.
It's time to take care of some of those little annoyances.
) I notice that the bulb socket itself is just a press fit into the rest of the housing and both sockets were extremely loose. Problem identified. With a multimeter I was able to see that as the truck bounced around the bulb socket would lose connetivity with the housing.
Not elegant, but it got the job done. No more flickering lights.
no problem man. I'm glad it was useful to someone.Same issue here, thanks for the details, Ashman!
I was only using 0.023 wire and the welder sheet recommended 0.035 flux core for bigger stuff, so I went out and got some. It's my first time with flux core, so the welds weren't pretty, but they did pass the BFH test.
), but otherwise I think this will work out pretty well. The main tube is 2x3 .120 and will be 5' long. I "think" I'm going to try to locate the spare to the passenger side to help with the leverage, but I'll have to see how it looks. Ideas are welcome.As some of you may know from this thread, I've decided to build a swing out tire carrier. I really need a place to mount a spare (I haven't been carrying one for awhile) and I want to make it somewhat modular so that I can mount a tray to it for some extra storage capacity, maybe some fuel cans, and also a bike rack. The bike rack and tray will be removable since I won't need them all the time.
I'm still trying to decide on the final design, but since everything starts with the main horizontal tube anyway, I decide to start putting it together and see where it takes me.
I went with the 4x innovations hinge. I liked the double shear design and they claim a 1000 lb capacity. Should be plenty.
Here is everything that came in the kit.
Since I am a self taught welder and this is my first time welding anything that has serious weight on it, and would be big problem if it failed, I decided some practice was in order. I only have a 110v welder so 1/4 plate is right at the max of it's ability. I tried cranking up the voltage just to see if I could get it to work, and predictably, it failed the BFH test rather dramatically.I was only using 0.023 wire and the welder sheet recommended 0.035 flux core for bigger stuff, so I went out and got some. It's my first time with flux core, so the welds weren't pretty, but they did pass the BFH test.
I mangled the piece of scrap I had pretty good with a 10lb sledge and the welds held. I'll certainly be asking for more advice before final welding, but I figure I can make some good solid tacks for now, so on to the mock up.
R.I.P. CK5 sticker:
I'm going to have to relocate my license plate (and ck5 sticker), but otherwise I think this will work out pretty well. The main tube is 2x3 .120 and will be 5' long. I "think" I'm going to try to locate the spare to the passenger side to help with the leverage, but I'll have to see how it looks. Ideas are welcome.
Hopefully I'll have more progress to report this weekend.
I ground it down to bare metal after removing my ck5 sticker.Thanks Greg. Pulling the bumper does make sense. I'll do that for final welding.
Luckily I am smart enough to know not to try to weld to paint.I ground it down to bare metal after removing my ck5 sticker.
I do have a lot of scrap around so I'll do more practice. I really don't want to find out the hard way that my welds were cold.
Good idea. I'll do that. If I can't get bolts in, I'm sure I could at least get some plug welds in there. The bumper actually has a bolt on cap that I removed so that I could use the clamps to hold the hinge in place.Also, not sure what sort of clearance you get between the round sleeve and that weld-on bracket, but you "might" be able to drill a couple of through holes and sneak some GR-8 bolts through the bracket and bumper as an extra safety margin. With the bumper uncapped like it is now, it's easy to get a wrench in there to hold the nut. (I'm sure that's why you left it that way)
-G
