The 208 isnt too bad once you get in there. You just need basic hand tools and a decent set of snap ring plyers
I have not. I probably should give that a shot.Have you put the back end up on jack stands and put it in gear just to see if that helps chasing it down?
hmmm... I'll have to check into that. I don't have yokes on either side of my transfer case though.I have seen this before, make sure your drive shaft is in phase , yokes in line clips in line. If you have it out it will cause that problem.
Do you do anything to change either angle on your rear shaft.
Like move the transfer case forward or back that would have changed the angle of the ujoint.
As for phase I was talking about the ujoints in your yokes on the driveshaft being the same.
uggh... sounds expensive...Looks like it may be time for a 241, SYE, and a CV rear shaft.
It shouldnt be straight, it should be the same angle as the joint on the case. If you are running a CV then it should be straight at the axle.Isn't that supposed to be straight?
But think about all that money you saved doing the exhaust yourself.![]()
Well, at least we seem to have found the problem.7* difference will cause vibration. They need to be the same or real close to the same
I got a couple of 2* shims from bigblock72 to try out. Since that wasn't enough to get all the way to even I tried shimming the pinion UP first so that the lower u-joint was basically straight on. If anything, it made things worse. So, this morning I flipped the shims around so that I'm shimming down now.Would be ideal to shim real quick and see if that fixes the problem. And if it does, then go ahead and reweld your perches.
) and what I'm thinking is that the driveline is the problem but it's causing the noise to come from the transfer case. Basically I think it's shaking the snot out of the case. The drive shafts don't feel loose when you try to shake them but the case is leaking from the slip yoke and from the shift lever.
