I had to take the front axle apart again. I messed up when installing the front locker. Turns out it's a zip locker after all btw.
I finally got the air lines hooked up so that I could test for leaks, and it definitely leaked. Pulled the diff cover off and the air line was ripped off.
The seal ring had spun around and that ripped the air line. As you can see in the image below, the seal ring was able to contact the bearing cage, so when the cage spun, it pulled the seal ring around with it.
Luckily there is no real damage to the bearing cage. The seal ring is probably fine too once I braze on a new line, but since I had to order parts anyway, I ordered a new seal ring to go with it.
The part I was missing is called a "master shim". Since I got the locker used, I didn't know it was missing. It fits in between the bearing race and the seal ring and keeps the bearing from contacting the ring.
Honestly, it seems like a dumb design to me. If the spacer is required to be there, why not just make the seal ring take up the same space and avoid the extra piece?
Maybe once I get it and go to install it, it'll become more evident why it needs to be two pieces.
