Well I got the dipstick tube out, amazingly it was the regular twisted easy out that saved the day. The ignition wiring is done, radiator is in, most fluids are in (found out that I have a hole to plug in the block)
, knew it was there but forgot till antifreeze came out
. I picked up the battery, got the oil system primed, Got the rams horns on, and got the temp/oil gauges hooked up.
Still have to make some short drops for the exhaust to get it away from the fuel and tranny lines. Top off fluids when it starts running/pumping stuff through the system, Hook up tach, put dash cluster back in, buy radiator cap
, and double check everything.
With any luck the exhaust drops wont take long to do and I can get it started monday afternoon. My neighbors are gonna hate us
. Twin 18" 2.5" open pipes running in a 12x26 garage(BASS TUBE
) at 2000 rpm for a half hr. Glad we have earplugs
Picks to come
