yee haaa, yes we do. You got lots to do before April
If there is one thing that BB should have taught you the more time you have on your truck before you make a huge trip the better, even the best can't predict all the problems they will have
Yes I do Eric...I have 3 pages hangin' on the wall in the shop, and write-ins getting added here and there as I think of them.
BB10 taught me a lot, it also set a hook pretty deep in me, and its getting reeled in a little more each day
That's where I have mine.
You can also get it from any of those small pipe plugs that run along the oil pan rail just above the oil pan (except for the larger middle one which is the coolant drain)
Heath there is two threaded plugs above the filter, one a 1/8 and the other 1/2....Now in the old days a true Hiperf block had both tapped for an oil cooler, with one flowing out,the other return I assume. So it would seem like there wouldn't be equal pressure on them both???? Am I thinking wrong?
