Bummer man, but you can get it back in. One time I was running late on a project, my first auto trans rebuild, because of a faulty part I received. Well, I got the correct part on Friday morning around 10 AM, at 11 AM I was jacking the trans up into my truck, and that night I took off for a 4 hour drive to silver lake to meet the family. Talk about hoping I did it right. I guess what I am saying is, even if your putting the trans back in the day you leave, you can still make it. And you have a trailer...
strap yourself to the trailer work on it on the drive out here :rolleyes:
Dam, thats good Keith...:haha:
So dave I could be there around 7 on friday an work till early am if needed. Let me know.
Right now I'd say yeah Jess, come on, I'm sure even if things fall together without issue there will still be plenty to do. If you want to crash here for the night its not a problem either.
Hope you can get it sorted out Dave.
So close! Good Luck man!
Barring another major malfuction, I'll make it somehow Max!
Today, I made a few mods to the cradle support crossmember, resealed the 205 rear cover bolts (fluid was seeping out of the threads on a couple) eliminated 2 of the exhaust pipe supports to ease crossmember installation, and found the 2 gaskets I need for install of the doubler to the trans again.
Also got the rear seats installed, but need to fab seat belt mounting back there yet.
Also started on the brake system....which leads me to ask:
I'm using a Corvette M/C for 4 wheel discs, and it looks like the reservoirs are pretty much the same size...I know this m/c used the same calipers and discs on all 4 corners of a Vette, so does it matter which reservoir supplies front or back?
I think it still might matter, the one closet to the booster is usually the front correct?? and even with out a prop valve dont the fronts still activate sooner????
I could be totally wrong, I don't pay much attention to brakes they only slow you down.
I know that is the way the Vette m/c is hooked up, just was wondering if it HAD to be that way.....I'll hook em up that way and find out!
8 days to go:
Complete body mounting and cage bolt up. DONE
Build driveshafts DONE
Figure routing for PS/hydroboost hoses/ Make hoses DONE
Fabricate oil coolers lines DONE
Install wiring…help JEFF
Route and fabricate front brake lines DONE
Install rear brakes DONE
Bleed brake system
Engine:
Install temp sender DONE
Install oil pressure sender DONE
Install radiator core support DONE
Figure overflow bottle mount DONE
Install shifters/linkage DONE
Engine start up
Check trans fluid @ startup.
Check cooling fan operation. DONE
Check for oil cooler leaks. DONE
Install driveshafts.
Test drive.
Check drivetrain operation
Check suspension operation
Change oil/filter
REBUILD TRANS
INSTALL TRANS
INSTALL DOUBLER...DRIVESHAFTS...SHIFTERS
HOOK UP TRANS LINES...REFILL UNITS W/FLUID
TEST DRIVE..CHECK FOR LEAKS..
Front Dana 60 axle:
Check caliper mounting
Check all lugnuts for proper application
Torque all fasteners
14BFF rear axle:
Torque all fasteners DONE
Body/Frame/Suspension​
Seat belts
Install headlights, tailights, turnsignals
Modify front fenders for tire clearance/Install
Install tailgate
Install Hood
Vent all drivetrain w/tubing
Seating DONE
Valve cover venting/PCV setup/ check hole grommets for fit DONE
Vacuum advance source DONE
Vent gas tank/tipover valve DONE
Misc. items
Mount front winch bumper
Mount rear bumper
Fab and Mount midframe skid plate
Fab and Mount fuel tank skid plate
Install windshield DONE
Install rear roof section DONE
Mount 9.5XP winch
Install winch fairlead
Figure winch cable routing
Mount spare tire
Install rear brake valve handle
CHECK TORQUE ALL SUSPENSION​
CHECK TORQUE ALL STEERING
CHECK TORQUE ALL DRIVETRAIN
Check tie down points on frame/suspension
__________________
Wish list​
Fab fire extinquisher mounting DONE
Figure trans temp guage placement and needs
Figure Hi’lift mounting
Figure and fab mounting for coolers, spareparts, toolbox, tote bins
Fabricate rear battery mount DONE
Fabricate 1.5” Tube grille
TOW TRUCK/TRAILER​
Install new trans cooler
Check PS cooler
Aim headlights
Check fluids in drivetrain
Check tire pressure
Load...tools..spareparts..cooler..map.
Check spare tires.
Lugwrench/jack for flat.
Install tie down rings on trailer.​
Generally from what Ive seen the rear res is for the front brakes.
Are you doing a prop valve or are you running larger lines to the rear that what goes to the front, so more pressure goes up front?
With your list I can see you still have allot to do... wish I lived close enough to help you out.
You are doing great.:waytogo: :bow:
KEEP IT UP!
WE ARE ALL CHEERING FOR YOU MAN!!!
I'll be putting in an inline adjustable valve to the rear brakes, and will plumb the front res. to the rear line as suggested...thanks rusty!
KEEP IT UP!
Yeah a cheering section....:thumb:
I will be part of the cheering section.
Good luck with it.
Me too man GO ZIM!!!!
Get it together we will go over everything after everyday just to double check things Dave.
Anything you want me to bring to the bash that could ease a major problem?
thanks for the backup guys, it really does mean alot, and gives me more ambition to get it done.
Eric my majors are the trans and brakes right now....gotta make sure it go's and stops, then the skidplates, which I have steel for, but gotta fab em up.
I'm going to bring along my undersize spare, and rim, figure we can mount it there if I don't get to it here, and got some tire repair plugs and kit, extra plugs, and 3 cans of ether, a bucket and need to bring a butane torch to light em off. Should I bring my hi-lift, or a bottle jack????
The trans guy said I need a drum, and he's having a hard time finding it today, but he should be able to get one pronto tomorrow. I wish I would have asked him which one for sure, but I assume he means the forward/reverse unit drum. Also said the assembly looked good except for......ready?
The outer seal on the forward apply piston had a cut in it.
I also took him a 4x4 case I aquired to put it all back into.
So I know he wants to head out to Indy tomorrow for the US nats, so I'm sure he'll get on it ASAP.
In other news, I got everything ready as possible to put the trans, doubler, crossmember, driveshafts, shifters, etc back in hopefully without to much hassle.
Also got a couple brake lines and the APV for the rear brakes mounted.
I need to check my Vette m/c for piston bore, and if its not at least 1.125 I think I need to go with a different m/c, from what I hear it's just not enough volume to feed the D60 calipers and K20's on the back. I thought I would try a 99 2500 m/c but don't know if the bolt pattern is the same???
Teck did you use the C3500 unit with the big reservoir then? I've been reading that thread for a while now, seems plenty of people have had good results with a stock system as long as its in good shape. I have a 82 diesel hydroboost unit with pedal too, so I'm going to go with a m/c for that combo....
