That will do it.![]()
Can I ask what is the purpose of the triple feed?
Angles.
as Adam said, they are made so at basically any upright angle, it will have a pickup in fuel. the pickups are made like a check valve, so that if the pickup becomes uncovered it will seal itself off and allow another submerged pickup to draw fuel.That will do it.![]()
Have you seen this setup now so you don't have to use rubber hose to the pickups
http://www.pirate4x4.com/forum/15169410-post100.html
Yes...another road trip to Iowa coming up!
I'll have to meet up with ya somewhere along the way if possible. I can give you your manifolds back thenI'll have to meet up with ya somewhere along the way if possible. I can give you your manifolds back then
I believe there is a formula for figuring out tank capacity, by the measurements of the tank, any one know it?
