finished up the wiring today...and Mike I did solder most every joint...I had a couple I didn't have a solder type connector for, so I used a solderless/shrinkwrap type on those.
Need to do the plumbing tonight when I get home from work, and hopefully it will fire up without issue...fingers crossed that all goes well!
I see I will need to first check fuel pressure at the regulator, then enter a temp setpoint for the fans to turn on, and the idle speed...any other issues I should look for?
