You can see where someone already tried to fix that carrier bearing. They put all those dots in it to try and get the bearing to fit again. Didnt work forever. You gotta love a dana 70 to run them. Slang a 14 under it in less time and much less money.
Good to know!! I am not that familiar with them. But yea this was pretty beat.
I think the stuburban of wreckless wrench is running a 70 and they snapped the pinion last week in Moab. Not sure if the pinion shaft of a 14b would have survived what they did to it in the hot tub, but it does make one think about the strength of a 70.
The way you hammer on stuff I'd just go for the 14b and call it good. It's either that go 40 spline stuff on the 9" and spend a serious amount of money doing so.
Definitely something to think about. I am betting I would be more into the 9 inch getting it to the same base line as the 70 or 14bolt. I’m a 14bolt guy through and through..
Keep in mind the pick and pull's sell the 14B for $250
True, the nice thing is it’s an excuse to drive up there and its apart already so I’ll know the condition of it prior to even going up there. If it doesn’t make $$$ sense I won’t go. The fuel is 100$ I think there and back.
It would be a bonus too if you manhandled Dave's transmission in for him while you are there. Since he can't seem to get the ambition get moving on his own.
Would you have to switch to 5 lug hubs? I assume you would keep your nice rims.
We tried to get methods but they didn’t have stock in the ones we wanted. Said we would have to order 100 for them to run them in 8 lug. The forged ones were available though but they were to much $$$ for me.
Damn that sucks.. I’m not gonna do a bead lock on this one. They’re such a pita and not worth the headache.. or I haven’t found out how much they’re value is yet lol
I made the same decision, been running around on 16.5s for 15 years, and it seems like beadlocks are usually leaking air and need topped off. So I thought, if I can get away with running 16.5, surely I should be better off with 17s that actually have safety bead lips inside them. And all the beadlocks added a lot of money and more weight too. If I did rocks at all, I'd probably change my mind...
I finally got the leaks slowed down some but it still is a pain.. also worrying about the bead lock ring bolts coming loose and shearing off was on my mind.. I guess I got lucky..
I was always afraid to go below 8/10 psi before R/F. What do you run on the dunes?
Lol 20-25 psi mainly to prevent broken parts and we see how well that worked out
And we would make fun of you when you got stuck almost instantly at those pressures. I ran 4psi with my old beadlocks, and non beadlocks I ran 8/10 like Heath.
That's true, those pressures would prevent broken parts here, it's hard to break hard parts when you can't go anywhere. ;) I suppose you could overheat.
Our sand must be softer or something, sounds weird but something must be different. I run 18/23 on the road, those big tires don't even need more than that or they would wear out in the center. I tried 15 psi when I first ever went to silver lake in '05 and I couldn't get up test hill after 5 tries. I lowered the pressure more and made it up the first try.
Baja must be more packed or something too, because I always thought, there is no way you could run 8 or 10 psi in a truck going 100 mph, the tires would blow from the heat build up. I go 70 mph sometimes but it's usually short bursts and then back to 30-50 mph tooling around.
The trophy trucks run about 35 psi I think... By the time they get to the pit and change the tire it's around 40-45psi
So I was running 15-20 for a while until I blew a tire, the race trucks run no less than 24 psi even with a beadlock. And it went pretty much anywhere I asked it to go, the sand is not powdery like you guys have or so I assume which is prob why I’ve been getting away with it. And rarely am i in super sandy conditions, it’s more hardpack and rocks
