Been researching traction bars, and been finding conflicting info.
Anyone with any good ideas? I know the angles and pivot points play an obvious roll in antisquat and all that. But does anyone have any solid pictures or diagrams of how each angle changes things?
A few pictures of the 203 mount.
Hopefully will get both taps here soon for the tie rod. Next going to knock out gear setup, driveshafts if the lathe can hold it, and sliders.
Rear end is finished. Need to find the little keepers for the threaded preload things and RTV the cover on.
Going to attempt to do the rear driveshaft tomorrow, along with setting the rear axle perches correctly. Then move on to the 60 front gear setup. Still need to weld carrier on it.
O'Reilly's wants 88$ for a 4l80e dipstick tube for a square. A bit on the expensive side.
Finishing up the HP60. Welded the diff. For whatever reason these reverse cut gears suck to setup.
He wanted 1500$ for it and the Sterling that came with the trucks. He let the 60 by itself go for 1000.
