Lol. This became a giant web of lies. I never even touched mine yet. I got the deck of the trailer down and stained. Then broke two holesaws trying to bore the trailer for the LEDs. I gave up, and zip tying the lights on for the day and then wired the plug to charge the winch battery. As to why that wasn't done I dunno, dumb.
Instead of mine we swapped a sf14 welded carrier in in place of the Gov bomb, totally redid the steering on the same 5.3 swapped s10 blazer. The ruffstuff heims were a much better design but didn't allow the angle the cheap crap ones did. So new drag link and had to bend the tierod a bit. Added some leaf spring clamps, ground the driveshaft and crossmember down because it's exploded a driveshaft every time so far. So limited it a few inches and now the driveshaft can be turned by hand at full droop. Diagosed a broken relay to starter wire. Hung some derelict wiring due to his cheap nature then installed some poly mounts as the cheap rubber ones were falling apart after 12,000 moles or so.
So, my idea of a non wrenching Saturday has been kaboshed. O well. I enjoy the rush of it kind of. I need a little chaos I guess.
