Got back to my house yesterday, yea 100 degree heat! Got out to the K5 in the morning and starting fixing problems from my rush to get ready to drive to Larry's a couple of weeks ago.
First up, fixing the switches to the console light and inverter. Just reversed the ground and load terminals. Bingo, it works like I planned.
It's bright, but diffused nicely so it's not a spotlight to the front of the box. Loomed the wires in the box too so it's tidy.
Figured out why I had no left rear channel too. Had to fix a crimp. System officially cranks. Think I might have pissed off the neighbors. Bluetooth on the deck is slick for the phone and audio. I've got a 10gb card in my phone for music and photo files so I ran through a few samples. Clear, good thump to the 6x9's with no distortion. The tunes will be great on the road or trail.
While I had the console up to fix the speaker wire I plugged in the external speaker for the CB. Needed to make a bracket for the speaker so I could hang it under the dash. Called my brother in law who runs the sheetmetal fab shop for a local heating/ac outfit to get some help. Now this is an easy bracket, simple "u" shape. Could have done this with a hammer and a block of wood. But I didn't have any material and I needed something else too. Get to that in a moment. So a quick cut on the shear, measure and set the bend lines and quick 90's on the brake. Easy. Used the existing screws holding the lower portion of the ashtray to the dash so I didn't bore more holes in it.
The other bracket I needed help with was the CB antenna bracket. I still had the one I made for the 75, but fitting on the 91 proved problematic. Seems over 16 years of production the bodies don't fit the same. The old bracket on the 91 has the tailgate hitting the bracket prior to it closing. I took the bracket to work before vacation and had one of my techs try to rebend it since he had a small brake at home. He tried, but it didn't help. So I decided to just make a new one with my bro's skill and correct tools. The gap on the 91 between the gate and quarter is only 1/4" so I have to get it right. We cut a chunk to size, laid out the bends and got it on the brake. Looking at both, using a brake vs a vise and hammer makes cleaner work.
Here it is in position. Got 1/8" to spare.
Punched the holes in both brackets and fogged them with a coat of satin. Still need to run the antenna cable. But I got a few little things that were nagging my brain done. Got a plan for the t-case mounting bolt holes. Need to bring the thread insert tools home from work. Using the same type of thread inserts we use on aluminum block Northstar (Caddy) V8's when they pull the threads out of the block for the head bolts when they over heat. Thread inserts are much stronger than heli-coils and will be a permanent repair. That will get done next Sunday. Also got a second battery to start making my dual battery setup. Need to order some stuff to complete it
