It won't have a fwd lean on the hwy!
Funny side note. The winged a-holes decided to come back and reclaim the spot in the quarter panel. Armed with my trusty shop vac I just sucked the little buggers out of the air when they got near the truck. Note to self, if you drive the truck wasps can't make a nest in it.
Changing the spring you'll probably want to double check your swr reading.
My new CB shat the bed this week too. Fired it up to cal the SWR, no dice.Yeah, about that. Until yesterday the antenna wasn't hooked up so no SWR readings taken. That being said once everything was back together I powered it up to make sure everything worked, stereo/amp, console electrics and CB. CB powers up, but no audio. Tried the weather, channel 9, 19 not even a crackle from the aux speaker. Not sure what I did wrong except I could have plugged in the external speaker to the PA and the PA into the external port. Or, the external speaker is junk. It came out of something else, but can't remember where it came from. Never tried it before. CB worked before in the 75 prior to teardown. One more kink to work out.
I can't imagine what the hell I could have done to mess it up. The radio is a nice Cobra sound tracker, but the date code showed 1998 so age is not on my side here. Got to try a couple of things before I toss in the towel on this one.My new CB shat the bed this week too. Fired it up to cal the SWR, no dice.
Waiting for a call back on the warranty.
Looks like some decent prices on Amazon.
I ended up getting a factory refirb ordered. Hope it works.
Good luck with that and the flying bastards...
It have an internal speaker
Sweet, didn't feel like getting a new radiator for mine.I do have the numbers at home, which I'm not at right now. I will tell you without looking they are stock upper and lower hoses for a 2001 1/2 ton Silverado with a 5.3. Matched the radiator we used (which was from the 75) like it was intended for it.
