B
C'mon Larry it really does not matter you are always in front of him anyway.![]()
Define "bit". The truck is gaining weight and will continue to do so with the fat block going in. The bumper is heavy as every bit of it is 1/4" wall stuff. The main section is almost 100 lbs by itself. Add the swingout, same size spare as what is on the ground and 3 jerry cans full of fuel/water then it adds up fast.I thought Rob was trying to change that with his engine upgrade. This thing is a bit lighter than the K10, no?
Well, that is good to hear!Define "bit". The truck is gaining weight and will continue to do so with the fat block going in. The bumper is heavy as every bit of it is 1/4" wall stuff. The main section is almost 100 lbs by itself. Add the swingout, same size spare as what is on the ground and 3 jerry cans full of fuel/water then it adds up fast.
After texting with Bill the bigger issue with the lights is accurately placing the holes in the bumper. The lights are large enough to reach from the top to bottom so if the hole is off a little the light is going to hang over the edge top or bottom. Right now we don't have an easy way to cut the hole other than the cutting torch. Plus the more I think about it, having a couple of large openings in the bumper will be an easy spot to let moisture in.
We need to get this done anyway because Larry's bumper is in line to come back to Bill to be reconfigured to run a different winch out back than the Smittybuilt he has back there now. Clock is ticking for the desert trip anyway.
Those lights were not going to look nice no matter how many excuses you threw at it.
I'm figuring that your drivetrains and bumpers are fairly close in weight, unless you stick with an aluminum transmission. But his truck is a bit longer, has some extra body weight, and his camper should be longer, too.
These are just guesses on my part. But if I'm right, you'd be flying past him on the climbs, for once.
Sealing out the water shouldn't be too difficult.
There would also be options outside of bumper mounting the lights...
1/4" thick is a lot to deal with when you need a fairly precise hole.
I picked up a pair of these strip lights at a TA truck stop, they are single pole, so they only come on with the brakes or with the turn signals...
Larry nailed the major differences weight wise between his and mine. One factor on the climbing will be gearing. I'm staying with the 4.10's in mine vs his 4.56's. Given the same tire size we run I'll probably be dropping to a lower gear a little sooner on the long passes. But that isn't going to be like what it is now.I'm figuring that your drivetrains and bumpers are fairly close in weight, unless you stick with an aluminum transmission. But his truck is a bit longer, has some extra body weight, and his camper should be longer, too.
Just before the desert trip last year I weighed mine with a partial load of gear and Ian's fridge. It came in at 5880. I didn't get it weighed before we left with a full load, but based on how full it was we were at 6300 easy, 6500 with Ian onboard.
That seems really light with the camper and the larger tires. My M1009 had a stock curb weight of 5200# with no interior furnishings. IIRC I came across at 5700# when in normal commuting mode (including myself, the NV4500, and 10.5" rear end).![]()
I think that's a fair estimate. I didn't take into account losing the gate/glass in the process. I know mine is heavier still due to the beefing up that was done in the rebuild.After getting a pretty good idea of the weight of my FWC while rebuilding it I really think it weighs about the same as a stock top and K5 tailgate combined. I am not sure if they are just bulky/cumbersome to manage but a K5 gate complete with glass is a handfull for me.
No kidding. But then again I'm running rough country springs up front. That chunk of iron might finally settle them down.Well, you might need zero rates front and rear after the fat block...
