I've been running Delphi pumps in the crew cab. Installed in 2013 and haven't had a problem.
I have another scenario.Well this is a new one.... Apparently I managed to crush my sending unit inside my gas tank... This is extra odd because the tank doesn't have a scratch on it.... I pulled the sending unit today because I though the sender was bad I guess technically it is.
Looks like I need to reinforce the factory skid plate.
Nope. I tried to straighten this and I could hardly bend it by hand and these drop down/fall into place really easy and the top of the sender sits flat with the top of the tank. If I had to push or force it down I absolutely would have stopped and rotated. The fuel gauge was reading perfectly before my wheeling trip but after it was doing weird things like reading 100% full then suddenly 100% empty and the pump got really loud (this is why I pulled it).I have another scenario.
Is it possible the last time you put in a cheap one in a hurry and it caught on the baffling and got bent?
So now you are saying there's evidence of the tank being smashed.Nope. I tried to straighten this and I could hardly bend it by hand and these drop down/fall into place really easy and the top of the sender sits flat with the top of the tank. If I had to push or force it down I absolutely would have stopped and rotated. The fuel gauge was reading perfectly before my wheeling trip but after it was doing weird things like reading 100% full then suddenly 100% empty and the pump got really loud (this is why I pulled it).
I have a theory... The factory skid plate kind of sucks on these... (look back a page or two at the tank I absolutely smashed with the skid plate on there) I think I hit it dead center and it flexed everything up 4-6 inches and the tank and skid popped back down. Since my skid plate is covered in a tar like undercoating I'm not seeing anything really obvious.
I have the factory skid plate on there. If I look between the skid and the tank there is the the 1" gap like normal and I can't see any dents on the tank at all. The skid plate also appears to be straight. What I was saying was with the factory skid plate I completely smashed my OLD gas tank and the skid plate maintained its shape. Here are some pictures I just took.So now you are saying there's evidence of the tank being smashed.
I thought I read there was no evidence showing on the tank, only
Yeah I am familiar with the skid plate, I had mine modified with bracing, otherwise it is just that, a skid plate, not a shield, no protection against an impact.I have the factory skid plate on there. If I look between the skid and the tank there is the the 1" gap like normal and I can't see any dents on the tank at all. The skid plate also appears to be straight. What I was saying was with the factory skid plate I completely smashed my OLD gas tank and the skid plate maintained its shape. Here are some pictures I just took.
Also attached are pictures of my old tank that got smashed with the same factory skid plate installed and pictures of this new tank that was installed right before my last moab trip.
@mrk5 I think you are right on the money. I think with the weight of the fuel and it being pressurized just enough it popped back into shape
Hey Joey @the_blaze, does this look familiar?Well this is a new one.... Apparently I managed to crush my sending unit inside my gas tank... This is extra odd because the tank doesn't have a scratch on it.... I pulled the sending unit today because I though the sender was bad I guess technically it is.
Do you have a good vent to prevent vacuum when it gets cold?Hey Joey @the_blaze, does this look familiar?
My discussion is here: https://ck5.com/forums/threads/89-r3500-crew-cab-2wd-to-4wd-conversion-beyond.303347/post-4195955
I am guessing spun the drum?Go guess what PB did on the dyno
View attachment 402009Login • Instagram
Welcome back to Instagram. Sign in to check out what your friends, family & interests have been capturing & sharing around the world.www.instagram.com
I was pretty surprised...
For Stock tbi?330/380
and a great looking calendar pic!
For Stock tbi?
Liked for the calendar pic!330/380
