I run 42s with a tbi 350 and 4:56 gears. It doesn't like hills much but does okay on the road. With 5:13s you should be fine I would think.
@skunked, are you running the nitto trail grapplers?
I found a set used that the guy claims have less than 2k miles on them.
He wants 1200 for the set im trying to get them for closer to 1k,
Are these decent tires? Think that sounds like a decent deal?
You guys running 40s,
Anyone still running the stock style push pull steering?
Because i only have a 3.5"lift doing crossover is not happening any time soon.
Ram assist was brought up but ive never played with that idea before
I would make crossover a priority. You don’t really need assist until you get a front locker, at that point it becomes a necessity.
Do you have an example of what you mean by strap the drivers side?Should be able to do it with some bumps and a bent drag link. Otherwise you’ll need to strap the driver side with the stock push pull.
Not sure i follow lol.Not off hand.
Just have to strap from the axle to the frame. I’ve seen guys go eye to eye on the shocks, you could probably get away with that temporarily. You’ll want to limit it right before your drag link ends are maxed out.
I would crossover before upgrading tires. I would also do hydro assist before upgrade tires.
