You need the passenger drop. You can't just clock it.
You got the ideaQuestion on the ord crossmember, it says to have the vehicle level with even air pressure in tires... i have my little trailer tires on the front, thats not going to screw me up right? i imagine they are more worried about side to side being uneven vs front to back right? part of me was tempted to lift the truck and put my giant jack stands under the frame so my suspension would drop and i would have the most room to work.
(btw i ordered all my mounts and the crossmember)
Cool I think if anything jacking the truck up and having the frame set directly on jackstands will likely make the frame as straight as possible.Yup more room the better
I made a cross bar for a buddy, so that he didn't have any more stuff in the way under the truck. No jack, or engine hoist legs. He used ratchet straps to the exhaust to lift the engine.
I made it out of square tube with a piece on each end to set on the flange of the fender. But you may not want to spend that much time getting rigged up.
It needs to be there to apply pressure to the other pieces of metal inside the poly bushing. I asked the same thing forever ago and energy said it was necessary for long life and it to work properly.
