144 inches or 165 inches are the 2 standards.
Tell me how you Really feelThe china made lifts do not require as much concrete because the lifting arms will break off first.
What model bendpak did you get? I'm looking at those also. They have a couple 10ks listedI saw arms break and the impala land nose down. Right front broke first then the left front did. Metal failed next to the weld. I am glad I was standing outside. The 2 guys under it said they heard a creeking noise and ran, luckily towards the door where the back of the car was.
Saw another lift that had broken. Welds were cold and separated.
One less set of studs and lug nuts to fail assuming you are using bolt on spacers.Let's start a political discussion....
Do wheel spacers really create additional stress on your rig?
I run 2" spacers with H2 wheels.. if i got new wheels that put my offset exactly the same as my H2s with the spacers is it really any better? Why or why not?
To run my current setup a think so...Are the spacers necessary to run the wheels?
I had good success with my 2” steel spacers and H2s - lots of miles, with normal service. Properly torqued, I wouldn’t hesitate to endorse them if that’s what you wanted. However, for the cost of good quality hub-centric steel spacers, I’d recommend putting those funds toward wheels with the backspacing you want, especially if you’re looking at beadlocks as an eventual purchase.
David
