Depends on the flavor, but they're better than snakes
Cleaned a bunch of junk out of the IAC, replaced all of the vacuum plugs and a new PCV. Acts more appropriate, but will be checking it.
Unloaded the HP into the garage and got it up in stands to start the disassembly
At least spiders have a visible means of moving about. Snakes move unnaturally. Something just not right there.... :rotfl:
So, couple minor things.
Dropping RPM still on deceleration, tries to die before catching itself. Put a volt meter on the TPS, running .555VDC at closed throttle position, 3.5 VDC WOT. If you drop the butterflies shut, it drops to ~.4 VDC before returning to .55. Think i have a bad TPS. Adjusted the idle screw just enough to move it off that spot, and will drive out tomorrow.
Sounds like my Steinway™ sliders have shipped. Guess I'll beat the rockers back out!
