Make sure you line the inside with thick mil plastic. If you have varmints lay the tight weave chicken wire across the bottom.
Care to elaborate on needing the plastic? I'm learning as I go here...
Grass, kid, dogs.
The bed will be connected to earth, but we are planning on having pavers around the outside, and the dogs do not have unsupervised access to that part of the yard.
Also keeps burrowing critters and weeds from coming up into it. Good idea if you want to basically isolate that soil from the rest of the ground under it and may also help with keeping your moisture from draining all the way down into the yard.
the boards on the side will shrink, dirt and water will exit between the boards and look like shit. Just on the sides, not the bottom as you want that to drain usually.
I made a couple a few years back but I used doug fir because I'm cheap.
Everything is making sense. We were planning on weed barrier throughout the inside but I like the plastic along the walls.
How about just cutting in a trim piece and laying it in there?
I was trying to figure out if I had subscribed to a garden thread.
I was pretty sure I hadn't. Then I was wondering what thread I had clicked on.
I'd rather see his garden pictures than read some of the derailments that happen here.....
Martin
Wifey knows that once I am done with her "mama house stuff" in the back yard, I am going straight to work on my other green project.
