Ended the night last night with the FiTech, dizzy, intake, and V/C's off, both serp brackets off, lots of wiring disconnected, radiator and fans out.
Spent a bit of time today cleaning up old gasket material and re-installing the intake. I took the wiz wheel to the contact points between the serp brackets and the block, heads, and intake, and then re-installed the brackets.
I took the old power steering pump down and warrantied it, and then put the new one on.
Tried installing the aluminum valve covers, but the bolts bottomed before the valve cover was tight, so no go on that. Then it started pouring rain, and dinner was ready...
