I can just pull mine apart. Unless you want em earlier. Like has been said I can just use 10 bolt stuff. Not even sure if I'm gonna use this 44 at all
I should be fine with waiting until you come down. I won't need it until I start putting it back together.
I got some more stuff delivered today.
That's why your truck looks nicer than mine
Got a few questions for you guys ("y'all" for you in the south).
I'll be mocking up the spring perches tomorrow. I've got a CV driveshaft, so I want to aim the pinion at 1-2* down from directly at the transfer case, right?
I'm using ORD perches which will allow me to move the axle forward or back 1" or 1-1/2". Any of you first gen guys have experience with what's best?
I'm also looking at buying some better diff covers, but I don't want to break the bank. Thoughts on these?
https://www.4wd.com/Jeep-Drivetrain...spx?t_c=12&t_s=237&t_pt=4041&t_pn=BTFBTF11066
https://www.4wd.com/Jeep-Drivetrain...spx?t_c=12&t_s=237&t_pt=4041&t_pn=BTFBTF11073
If you can weld that w/o pinholes, doesn't look like a terrible deal... Want to see some others weigh in.
Kinda. You want the pinion 1° to 2° down from being the same angle as the driveshaft.
Thanks. That's what I meant, just didn't phrase it correctly.
@bent72 I'm still trying to decide if I want to paint the diff covers something other than black. Doing something funny like that does have appeal. Or maybe wuss out and just paint them yellow. :thinking:
Since they are supposed to be welded inside and out, I figure I can get it to seal up ok. Assuming I don't manage to warp the seal ring.
I went ahead and ordered them up. Hopefully be here next week.
Don't know why it didn't occur to me to bolt them to the diff for welding. :doah:
Hey
Bolt that to the diff and weld it....
Maybe something funny but in yellow
