So I blew the dust off Lucy on Memorial Day, what better way to be american and be thankful for all the amazing things we get to enjoy than fabricating for a morning!
These dash tubes have been made for a while, I squares them up and welded them in, and of course the welder decided that the liner needs to be replaced... ughh I am so tired of inconsistency on the machines part. My goal here is to finish the major fab that requires the big shop tools and to get any major system working. So for now I'll use the stock brake lines and fuel lines to save time. I'll build some long braided brake lines front and rear. I need to have the rear driveline redone with the 1350 up at the trans to handle the angles. 1310 is hitting right now.
The checks that have been marked now are, rear axle is done, brakes are on and welded, gears in, installed and sealed in the housing. All that is left is the vent line.
I have decided that next year sometime I'll re build the engine cage when I get shorter front shocks. That way I can use the 17s in back on a trailing arm. For now I'm gonna leave it with tree springs in back and with the cantilever. If it works good we might come out with the design for sale.. we'll see.
One other thought I had was to ditch this column, I know where a good tilt is and it has the smaller gm wheel on it. This one is rallied and moved inches up and down and is not supposed to..
Here is a generic idea of the location of my shifter, not sure if this is where I want it or not. I gotta get one of the two midgets(
@secutright or
@retroblazer) to sit in the truck and see if their short arms can reach it. I already know they're gonna need booster seats. My shoulder is just above the window line for the drivers door. I did this so I have room for a helmet and not bang my head on the b pillar..
