It is your fault!!
I literally made me think this morning screw it... Heath is right I need to get my ass going and what am I waiting for??
Sounds good to me, time to get that beotch fortified!
It is your fault!!
On it!Sounds good to me, time to get that beotch fortified!![]()
The only regret I have and it’s mostly due to this being the first of the trucks ive built, is there are places that are not perfect or how I would like them to be..
I suppose that’s how this goes. Not every weld is easy to access, or every bend the same as the opposite corner, it will likely lead me into redoing a lot but that is ok.. act 2 will probably happen in a couple years or in stages.. there is already a plan to test a arms and awd.. so that can pave the way for more advanced prerunners or race trucks that still want a k5 frame or something that will bolt to a k5 body.
I am going to try to do what I have to get it running, I just found a big mess up yesterday that has to be recified before it can be driven, I somehow messed up the angle on one radius arm. So Im gonna have to built new arms but this set will be adjustable!I'll 2nd that. I have re-done so many things that I first did mostly because I had no idea what I was doing, Some of it still bugs me 9 years later(Mostly my cage not being totally perfect and some of the early sheet metal work ). Funny thing is I kinda want to go back and change or lets say re-do but a lot of it ain't broke yet so I live with it. Keep chipping away I'll try to keep my rig alive
Let’s not make this too complicate ok... Ford did a pretty good job with the steering on the twin I beam suspension. This bronco should be pretty sick basically stock.Did you ever see where ORD put the steering box in Wally a few versions ago?
They had it in the middle. Ran the steering linkage around the frame and positioned the drag link so it worked.
Sorry Steve... couldn’t help myself. Keep up the good work man. I wanna see this thing in action!Thanks a million but I am not the fabricator that @secutright is, next time I’ll have him build this for me.. it’ll be nicer that’s for sure! I am just a guy with a grinder and bad ideas!Cool project, awesome fab skills
I have seen that. I was trying to avoid some crazy mounting setup. But we did have a conversation about using a bellcrank and I decided that moving the box was easier.Did you ever see where ORD put the steering box in Wally a few versions ago?
Just for mock-up, this allowed me to adjust the length without cutting more steel up. I’ll build new tie rods once it’s all triple checked and works how I would like.Whats the different length sleeves on the tie rods for?
