WOw Jesse made an appearance!!
So I actually got the dana 70 apart! I pulled the carrier out and found out what was making it so loose, the shims somehow got eaten up?? is that normal?? but the gear set looks good enough to use. I am going to order a bearing kit and seals once i get it fully taken down and cleaned up. Ive gotta get the disc brake brackets for it at some point.. part of me might just say FK it and use the drums if I can get them unstuck. the master cylinder still has the residual valves in them.. well see though..
