Maybe it's just the pic, but the passenger side rail looks a lot lower than the driver side. If so, try to straighten them before you go any further. Gonna get a lot worse the more tube you throw in there.
Haha yeah not too shabby! Thanks! Might try and make a couple more and see if they sell.That tundra bumper turned out clean!
I think it's just the pic and the uneven jack stands. But yes, the frame is bent.Maybe it's just the pic, but the passenger side rail looks a lot lower than the driver side. If so, try to straighten them before you go any further. Gonna get a lot worse the more tube you throw in there.
Hahaha....I've been wondering why it's been chowing tires!!!That little plate on the upper shock mount doesn't really add anything strength-wise.
The thinnest part of that mount is right next to the tube (it's only about 1" thick/tall) so THAT'S where the mount will fail... instead of putting a flat plate there you should try to add two vertical plates to extend that area upward (one for each side of that bracket) and cut them so that the follow the curve of the tube and wrap around it as much as possible. That way, you increase that "thin" spot from about 1"...to maybe 2" and make it more impervious to the loading that it will see.
After that, you can cap it with a flat plate if you want.
.....also, check the toe-in spec on your front axle. Looks a bit off.
-G
I'm having trouble visualizing what you're trying to say but I'm guessing this?:
Finally found some 8 lug wheels for BlaZeus! Found on CL for a smashing deal. They are Pro Comp Alloys, 17x9 and pretty much brand new. This is a big break through as I have been searching for months, waiting for the right wheel deal to come up in my area. So I was able to finally get the 37" Toyo M/T's mounted on these, which I also picked up for a great deal awhile back.
#ultimatebudgetbuild
Thanks! Any idea on approximately what page??? Lol. You've got a long ass build threadhydroboost or bust. Its fairly involved though. Really should buy the steering pump to go with said hydroboost unit as its a little better then doing a T. Also snag the boost unit from the junkyard. Theres a stupid ass pin inside of it that doesnt exist...as in you cant buy it anywhere. Without it youre dead in the water. I bought a reman unit thinking i was good to go....luckily a cool guy on here gave me the pin. If you check out some of my most recent build thread pages i have a lot of info on hydroboost as far as installing. Youll have to make a plate unless the junkyard comes with one. Theres a special stake nut on the back of that. If you dont need to take it off then its no problem. If you build a plate like myself then youll have to either buy some stupid expensive socket or you could rent mine i made lol.
Oddly enought the unit i bought (all 1987) lined up with the brake pedal. Thats sort of as far as i got as im jumping from one thing to another to keep myself busy.
