On the trim that fits inside the main weatherstrip, start where the clip was when you first pulled it off. Pretty much reversal of how you remove it. Try not to pull the trim as you install it so you will have less to trim off. I just used a small screw driver to push it into place.
I didn't take pics of the clip install (beer), but all I did was: after trimming off any excess, put one end of the trim halfway inside the clip and as you get ready to press into place put the other end inside the clip and then slowly wedge one side in and I used a small flat head screwdriver to pry the other side into place. Install complete
