I'm completely realistic this truck is not going to get 20 mpg. Maybe downhill with a tailwind, but most of the time I'm climbing up in elevation. I'd say I would be happy with 15 mpg. That might be a tad optimistic, but if my rpm at 60 is any indication it's optimal for good mileage. It's pulling 1700 rpm in 4th (tcc clutch off right now) at 60 mph. Not bad with 4.10 gears.
Today's fun started with replacing the dead invertor so I can run the laptop on the fly. I know it's not the best, but a 400 watt unit from harbor freight is only 25 bucks so I grabbed one. I got it wired up inside the console and got the laptop fired up.
I decided a cruise was due so I headed west to Beulah from my house with the laptop recording. It was an awesome late summer afternoon to run in. Warm down at home, but clouds were building where I was headed, plus I'm climbing up in elevation on the way. Beautiful country out here.
Totally spoiled this area is 20 minutes from my driveway.
What a difference a few miles and 1500 feet up in elevation does for the environment. It's dry and cooked off the foothills, but up here it's green and lush between the evergreens and hayfields in the Beulah valley. Sorry I got a little pic happy at this point, figured I would share here.
I stopped one recording and started another to gather some lower speed data as I tooled around the Pueblo Mountain park above Beulah.
Yes, dirt on the tires...Keep in mind this is just a picnic type road, no 4wd needed. Just a scenic spot in the trees to get out of the heat for a little while.
Sitting at about 6700ft of altitude here. At this point in the 75 I would have felt a noticeable loss of power from the almost 2000 ft of gain from home. The 5.3 never skipped a beat. It showed no loss by stabbing the throttle when needed.
Poser shot. Had to do it.
Then it started to dump rain. No wonder it is green up here! It was so bad I had to shut down the computer on the passenger seat and roll up the window to keep it from getting rained on. Lightening was starting to hit around and I started to make my way back down again. Out running the storm I thought it was pretty cool to look out and see Pike's Peak in the distance with the storm clouds overshadowing it.
All in all, it was a good drive. Need to put fuel in it as I went 50 miles round trip on this run. I'll run it to work to get a better gauge. The main issue I've noticed with this tune is an idle flare. First I noticed it idling in park if I throttle it, the idle goes from rock steady at 800 to fluctuating up to 1100 and back down again. If I throw it in gear and back into park it calms down again. I did notice it doing the same thing while putting around the mountain park at low speed. Watching data I can see the injector pulse width go from 1.5ish to 0 and back up again right in time with the idle movement. Like it's cutting off the injectors and turning them all back on again. Weird. Not sure what to do to dial it out.
