Looks great! It would be tempting to reskin the outside while you're there and get a modern black frame window with curved corners. Phx uses sheet fiberglass on the exterior. Looks so much better than corrugated aluminum...lighter too
Oh I've been tempted. Totally. But I'm trying not to go all the way down the MAW rabbit hole here. I want to get the inner structure and roof done so we can mount it to the truck. Exterior and skirt changes will come in phase two probably next year. I really wasn't sure about tearing it apart this far, but once it came apart inside it was pretty easy to see now was the time to make the big changes inside. So we can get the inside knocked out and get it mounted so it is useable and I can see where other changes can/need to be done.
It's getting close though. Just need to configure the cabinet and finish out the trim and wiring. Once the inside is trimmed out we stain and seal up the wood to match the original stuff. Then we can go after the roof. We'll have to replace some screws, seal them off and replace the roof vent. Then we can coat the whole damn thing to seal it all up.
