just find some 4x4 or 5x5 plates and turn them on a 45 degree angle, burn them in. Make sure to pull your fuel lines away from the frame before you do that.
. the question was do i need to turn them at an angle to make a diamond or if i could line them up flush with the bottom of the frame as a flat square. is there any benefit to having them in a diamond shape is what i'm looking to figure out
What if i used 4" angle and had it wrap under the frame ....In our situation not really.
Wut? No you have to cut the diamond shape.
just call me Captain Obvious
@the_blaze can't you just notch whatever body supports (body beams?) are hanging down so the supports contact the frame better?
Yes, and i will notch it a little but to weld behind it it will be more than a notch and thats where i get concerned about the floor sagging
I assume you'll be welding in a cage with the seats cage mounted right?
Also, if you notch it right (nice and tight) it can be welded to the supports anyway.
I think probably 18 gauge but it's stamped which helps rigidity. For replacement floor peices I'd be inclined to 14 gauge
But he didn't put the / between the 1 and 4!I'm pretty sure i would be building a tank if you had it your way![]()
Yeah, i just wonder if that one tire would even make the trip to moab...
