PLAN B
This build was 2 parts 1 i have a truck I made to pretty to wheel so I'm building an ugly one I can actually enjoy. And 2. My cousin has been trying to join us for blazer bash but his truck wont be ready so we are surprising him with this one
@skunked and others....
Did you have to cut the mounting tabs down or were they the right length?
I thought there would be some instructions but it came with zero.
Any tips on getting the ram lined up and in the right position?
What tabs?
How far up the saft should this go? Man i swear this is as tight as i can get it...
It needs to go more. You need all the spline contact you can. Plus the further away from the top it is, the more leverage it has to snap the sector shaft.
It shouldn't bottom the nut against the step on the shaft, and you have it mostly through. But not much thread past the nut
I think i have the wrong arm. Im using a 2 foot breaker and thats all she has.... ill call ord tomorrow
No that's the right one it's a 3" or 4" dripped arm for a Ford. I've had a couple where the threaded section of the shaft you could just barely see with the nut and lock washer on.
I have tightened em down and removed a pitman arm several times to get it to go on more. That sucks when you don't have air tools. I have also filed pitman arms to get 100% spline engagement. Used a press once, that was a little nerve-wracking, I don't recommend it
I mean i do have an impact i just dont want to break stuff....
Should i give it 30 ugga uggas?
Who knows... I'll call ord. I just hit it with like 60 ugga uggas and no movement. Ryan strong armed it. No movement...
