And just under 210*is normal for stock TBI.
Yes I do@the_blaze do you have heater cores hooked up in both of your trucks?
There you go, put heater on high at the lights.
i might even try the 7 blade fan just for kicks... i also have those windstar fans i could try... hmmmmm....
You ever heard of the term analysis paralysis? Meaning you might be over thinking just a tad.
210 is pretty dang normal for any fuel injected gm v8. They want the engine running at that temp to be most efficient.
I can totally understand wanting to upgrade due to the higher loads for wheeling. So upgrading to big block/diesel radiator, shroud, clutch and fan will work just fine. You just need to get all the parts together. The BBC/diesel radiator has a different top plate and hold down brackets.
210 seems ok to me, I don't see why you are so worried about it...
lol
