I have a hard time following what they are saying on that sheet i read it like 9 times lol
@skunked and others....
Did you have to cut the mounting tabs down or were they the right length?
I thought there would be some instructions but it came with zero.
Any tips on getting the ram lined up and in the right position?
Does that look right to you @1977k5?
I mean i do have an impact i just dont want to break stuff....No that's the right one it's a 3" or 4" dripped arm for a Ford. I've had a couple where the threaded section of the shaft you could just barely see with the nut and lock washer on.
I have tightened em down and removed a pitman arm several times to get it to go on more. That sucks when you don't have air tools. I have also filed pitman arms to get 100% spline engagement. Used a press once, that was a little nerve-wracking, I don't recommend it
Should i give it 30 ugga uggas?
