Everything checked out fine and it hasn't drained again. I think something was left on.Did you figure out the drain problem?
I'm going to "try" a new MC, the original part that came on the my truck.You need a master with a larger bore to move more fluid. I run this one and have a real nice stiff pedal and way more stopping power than I need. I do have hydroboost though.
That's how mine is. I'm running a 3/4 ton 10 bolt front and I have a 14 bolt out back with 1/2 ton calipers. Slightly smaller piston than the fronts. I did a disc/disc prop valve but it really made no difference. I added an adjustable one to the rear circuit and it is turned almost all the way off.My adj valve is also on the rear and I too ditched the oem valve. Mine is adjusted so very little goes to rear. They lock up at same time front and rear. Some scariness during testing until you get the rear not to lock up first.
