i got your red in the divorced style .
thats one i did under a truck with full twin stick and 1410 yokes on outputs .
0817131611a-jpg.149326
0817131612a-jpg.149327
Orange t case? You just trying to impress bent or what?
Yeah
Thats like a hot chick with midget legs
really I did the tcase in the blazer black and felt it was really understated. The engine is black ant I clear enameled the magnum so it's for contrast. Why not
She barely fits. Had to rearrange the tool chests and bull the bikes out. Pulled the 400ci and th400 in one shot. The radiator/trans lines were breach therefor I found where all the trans fluid went last time I fired it up 6 months ago. Put a gas truck engine harness back in.
Drop in went well. It was a really snug fit even with the 3" body lift but once in I have the three inches to lower if I decide. However this twin stick shifter is not going to work with the Allison I don't think. Even with a 3" tunnel riser the linkage won't clear... I'll get pics tomorrow. The ORD cross member fit very well. The engine mount on the passenger side gave up a fight though.
I recently saw in a magazine that a 2wd 6 speed Allison was actually shorter than a 2wd e4od. Thought that was interesting.
Is this a 5 or 6 speed? I can't remember. Are you doing the tapshifter setup?
5 speed shifting on the column. Right now I'd say it's only about an inch an a quarter or so longer than the th400 so I only have to lose 7-3/4 off the rear shaft
