The thing was the fan and clutch spec'd out for the Workhorse chassis is even bigger than the GMT800 truck stuff. When the clutch kicked it the sound was like a small prop plane on a take off roll. Some customer's got annoyed at the sound until I told them, if you don't hear it and it's hot outside you better look at the temp gauge because it's probably going to overheat. The issue came down to crappy airflow. I had one customer that was a retired aero-engineer (wind tunnel jockey) and he took little inch long scraps of his wife's knitting yarn and taped them in a pattern on the valve covers and intake and then drove it with the doghouse cover off. He confirmed what we suspected that the airflow at the rear two cylinders was little to nothing even at highway speeds. Add to the fact the way the manifolds are setup, the flow from the front two cylinders goes back to the rear of the manifold allowing more heat to be absorbed into the rear half of the manifold.
At 500 degrees a stock 8.1 exhaust manifold is a dull cherry red color. Those are cast stainless steel by the way. At 1200 degrees they are almost white.
