Yea Im waitin on your test I been fallowingonly headace i found in led swap was the front fender turn/marker 168/194 . i have new on the way to try and should be good cause there NOT polarity sensitive for the flip flop switching in that 2 wire unit .
look here for my thread on led swap over https://ck5.com/forums/threads/l-e-d-bulb-test-review-thread-for-1156-1157-194-marker.335580/
ya i know . i ment the link for @UpnAdam so he can read up on it if he wished .
you should have got the round 7 AND the flat 4 all in 1 unit = no more jender bender plug from hell to do flat 4 in round 7 .
Look closer... 7,4/5 underwrong plug buddy . . . .you should have got the round 7 AND the flat 4 all in 1 unit = no more jender bender plug from hell to do flat 4 in round 7 .
flat 4 on left side of plug with its own cap .
edited my post already . never seen one flat 4 under on bottom .Look closer... 7,4/5 under
Yea i just saw that. Kick ass! I never seen one on the bottom either that's why I got it when I was at Napa. It's a Hopkinsedited my post already . never seen one flat 4 under on bottom .
also led post in garage has been updated . problem solved with lights .
No its a courtesy. I couldn't see riding behind my buddy's 2wd 3+3 in the rain. I can only imagine the hell these boggers throw back.You got to run those mudflaps to be legal?
I'd imagine it is a piece of truck frame. Didn't notice a twist though. It's welded on so I'm makin lemonade with it right now. Eventually I'll make a tube bumper I supposeif i was a betting man your rear bumper started life as a med to hd truck frame rail by the looks of it . does the bumper have a slight twist from 1 end to the other ? i have made a few out of c-60 or f700 rail chunks my dad saved years ago from when he use to build firetrucks at the local factory when it was open .
Change your name to speedMr.niceguyDanNo its a courtesy. I couldn't see riding behind my buddy's 2wd 3+3 in the rain. I can only imagine the hell these boggers throw back.
If you change yours to pita bagel holeChange your name to speedMr.niceguyDan
