Correct, this is not the original engine in it was a 6.2 diesel1980 was the last year for the 400 small block.
Martin
Martin
It took a bit of preparation lolFinally huh?
12.4mpg average on the way back loaded but the 6.0 was working hardI'd be interested in the MPG difference you got loaded versus empty
Yea that mid strap was just a little reassurance for lateral movement. It was negative 18 when I pulled out n I was worried about the frozen rubber sliding off the side but it did well even though the tow points in the front were so close to the axle I had to go over the cab mounts (I know another no no) but it was super stable it was just hairy towing in the snow when at the top end of the truck and trailers capacityfrom a guy who tow's for a living that middle strap is useless almost and will have a short life span .
tie the axles down and let the suspension work .
if you tie down the frame it will bang and tear stuff apart and possible loose a chain / strap / or tow point .
other wise looking good .
and glad to see you got it from the snow home it was in .
That's awesome! Nice truck too!Welcome to the 3+3 family.
I took my kid to his first day of Kindergarten is this 3+3, and I will picking him up for his last day in High School as a senior this year in this same 3+3.
That's a 6.0 truck?12.4mpg average on the way back loaded but the 6.0 was working hard
That's a 6.0 truck?
You must workout.[/QUOTE
The white 2500 is but it's not mine
