I'm geekn' that I may have cruise if everything works out!
Did but all the photo eye yellow box stuff is removed. It should all be controlled by the ecm nowDo you have the cruise module that attaches next to the convenience center on brake pedal frame.
I hope they make rears I ordered a "suburban" set but only got two panels...Those door panels are super nice!
While talking with a friend, he told me about having to do a fuel trim reset on his 8.1 / NV4500 truck after a problem.so I fires it up after some volt tests. Idle till open loop. Still strange range issues with the pedal/tac module for 2003. It's smooth up to 5k if applied gradually but the pedal can't be stabbed. I think I'll have to find another 01tb and put the other tac module back in. As far as the run time, it was popping on the first lap around the block but by the time I was back in the driveway it was smooth. So I mau just need to drive/learn. Not happy yet
Well I've done some reading and found that they can wear out and cause the issues I'm having. It appears to be original and has 199k on it. It's also one of three original sensors on the engine besides the MAP and cam sensor. It's worth a shot. But I really think this harness may still be built wrong. The check engine light still doesn't illuminate during starting and it hasn't since I've had to correct their o2 sensor mistake under their direction.What helped you make that determination?
never heard of this can you find out more? I'm really out of options and beyond my skill level at this point. I'm ready to get a dart intake and carb and an msd box...While talking with a friend, he told me about having to do a fuel trim reset on his 8.1 / NV4500 truck after a problem.
I will try to remember, but I know that he is gone hunting this week. I am fairly confident that he did it with his scanner, I believe that it was before he got HP tuner software.never heard of this can you find out more? I'm really out of options and beyond my skill level at this point. I'm ready to get a dart intake and carb and an msd box...
I haven't done any tuning since the o2s, exhaust and whatever else I've done I wonder if I need to. The ecu is fresh from Howell however and I did let it idle to open loop before even touching the throttle.We did a fuel trim reset after my exhaust was done. We didn't have the o2 sensors in and it got run for a little bit. It was in open loop without them, but it noticably cleaned up once we did it with the exhaust completed.
