Now I just gotta figure out what to do with that green wire since there’s no longer an even…
If you were following you know it's not the 8.1 anymore.8.1's have a notorious valve train chatter that could be what you're hearing.
If you were closer, I would be talking to you.At the moment I’ll be keeping the Allison but the 8.1 probably needs more that it’s worth to make run. It’s basically a long block with 200k on it
so I changed the 45degree and 120degree ends and there we go! It’s a runner. It was dark out and I still need to bleed the brakes or overhaul the rear brakes completely but next weekend I should get to shake it down to see if it’s even drivable.It's been my life mantra.Well I got the fitech installed yesterday! Real down n dirty just to get it running other than the pressure side of the fuel plumbing. I made sure that was proper even though I hooked the tb up backwards and it wouldn’t fireso I changed the 45degree and 120degree ends and there we go! It’s a runner. It was dark out and I still need to bleed the brakes or overhaul the rear brakes completely but next weekend I should get to shake it down to see if it’s even drivable.
New mantra: “don’t get it right, just get it running “ -David Frieburger
So unlike me
"If you don't have time to do it right, how are you going to have time to do it again?"
